Ok, I'm finally going on the bottle. (hurray!) The problem is my trunk space.
I'm currently carrying around a 4.73 cu. ft. sealed box, seperate compartments for each 12. They're JL W0 8s bridged to 4 ohms, which maxes out my Alpine MRV-T707 at 600 watts, which is perfect for the W0s. I'm considering two seperate boxes, one in each rear corner of the trunk with the bottle between them, or a smaller box between the wheel wells. (the current box won't fit.) I'm also considering a single sub, but I don't want to lose all my bass.
Current trunk set up:
Actual size of box:
My questions are:
If I build a smaller box between the wells, should I face the box into the cabin (I think I have them firing backwards because it sounded louder, but I might have done it for show, it's been a while)
Can I switch to a single 600W 12 (instead of the two 300W 12s) and still get the same db level?
Can I switch to a single 600W 15 and get the same db level?
If I switch to two seperate boxes in the back, can I go with two slot ports tuned to different frequencies (say 25hz for one and 45 hz for the other one) yet still run both bridged together, or will it mess with the signal from the amp?
Any other suggestions would be appreciated.
Actual size of box:
My questions are:
