Shaved antenna solution
    Those looking for a hidden antenna.. well a low profile one, I have found one that seems to work great. It is one that I got from discount auto. You can get them from any regular auto store, it was 20 bucks. It mounts to glass and doesnt look too shabby. It requires a 12volt power to amplify the signal and works great. I couldnt get local stations before, and now i get stations from 2 hours away w/o static. It is model AT-UA200. I will have pics when i get time to really install it. Just wanted to let you guys know that it does work though.
    Heres actually a pic of what it looks like. Im sure they are the same thing, just different brand.
    http://cgi.ebay.com/ebaymotors/ws/eB...931155998&rd=1
    here's my setup:
    * interior mounted amplified antenna*
    ..the cables u see in the background is attached to the house, NOT in the car
    5.6L V8 32V DOHC
    JDM HERITAGE - US BUILT
      People still listen to FM radio?
      j/p, the antenna looks good. Satellite radio owns you though
      Honda-Tech Username: Lostcb7
      The cb7tuner.com OG.
        Originally posted by PRIMOCB7
        here's my setup:
        Same antenna that I have in my car.
          Yeah, thats the one i got... same exact thing. What did you mount the ground wire to? Did you lengthen it and ground it somewhere or is there something to ground it to up there?
            I soldered wire to it to lengthen it, and its grounded in the trunk with the rest of the wires to the stock antenna
              Same as mine too, but I put mine on the windsheild, so its not visible due to the tinted strip on top.
              Jay
              Hittin Switches - Draggin XhaustAlways Under Construction
                Jay
                mines not visible, because of the 5% tint on my back window, and mine is higher up, on the top of the window
                  how much was the antenna you guys have? How do you like it?
                  www.maketradefair.com
                    I paid about $18 at a auto parts store. The reception is pretty good, but not as good as the factory antenna. I wouldnt suggest it unless your factory antenna craps out, if it does then go for it.
                    Jay
                      I paid 19.99 at the auto store. I dunno how you say it isnt as good as the stock one. The only car that gets the radio stations that i can get is my dads 97 accord w/the antenna in the back window. Definately is good... it doesnt change anything though until you hook up the 12v power to it. Then it comes ALIVE!
                        hmm how is it hooking it up? Easy? My antenna won't go up anymore..and it gets like 1 station..so i guess its dead?
                          mine was also $19.99. Hooking it up is easy, Power (to turn on with radio) ground, and the antenna wire that hooks into the trunk location.
                            whats the brand?
                              Mine is Meira AutoWorks. It is the generic brand that they have at autozone... I guarantee mostly all of them are the same exact, just repackaged, cuz there is nothing on the antenna.
