I wanted to put in an indash mp3 player, i hooked up all the wires...white/white, black with black red with red..etc....but it wont turn on....the yellow is battery constant, and the red is +12v....why wont it turn on, its not that hard to hook up a cd player..but is there anything i can do to make it turn on?...i've tried my brother in laws mp3 player and his wont turn on either...and his is all wired up just needs to be naped to the harnes....
stereo problems..
fuses.
there is a fuse in the car in the fuse pannel and there is one in the engine bay.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
i checked the fuses, and a fuse in the car near the gas pedal was blown, and also a fuse in the engine bay was blown, so i changed them both. The wires are all set, taped off and none are touching, everything is hooked up properly. Is there anyway the cd player could have blown while the fuses were already blown? does anyone have any other ideas?
thanks alotBriBriBri
hey man i just had the same problem with mine wat i did is the yellow wire that is the constant might be another name to it. but wat i did is there was already a inline fuse on the so i added a extra wire from there and ran it to the battery well the positive side of the battery and it works fine just make sure the is a inline fuse and you jump off of the constant let me know how it works outUm......am i supposed to put something funny here?
does ur clock turn on?
check the fuses again to see if they blew again, if they did then u got something wrong in the wiring.
if u want to check the deck plug it into another car
usually u will smell a faint weird burnt smell if u fried it.
id double check
yellow powr
red ign
blk ground.
always have that ground in....if u want to test if u blew a ignition line then tap the red to yellow temporary and if it turns on then u kno ur ignition line may be screwd.
but do check other things.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
put the same deck in another car...see if it works, if it dont its fried.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Was going to say check the fuse in the deck...that will fry before anything is fried in the deck (usually)So, is that what you call a getaway?
Tell me what you got away with.
Cause I've seen more spine in jellyfish.
I've seen more guts in eleven-year-old kids.
Have another drink and drive yourself home.
I hope there's ice on all the roads.
And you can think of me when you forget your seatbelt,
and again when your head goes through the windshield.
And is that what you call tact?
You're as subtle as a brick in the small of my back.
