Keyless entry
    Keyless entry
    Hey yall I was wondering if i should go get a keyless entry while i have the door panel off? or if i can wait? The reason im wondering this is because its a pain to get that damb panel off, i figured id do myself a favor by adding the keyless entry while im at it, but im not even sure how a keyless entry work or where it goes. I was also wondering what brand other people have
    Can I get a Hell Yeah!!!
    My alarm has keyless, and it ties into the wiring down by the fusebox, no need to remove the panels for it. Keyless entry just pops your locks for you. There's a plug taped to the harness loom down there. And if you think the door panel is a pain to remove, you might not want to try installing keyless by yourself. The door is a few screws and a couple good tugs to remove. It's one of the easiest parts of the car to remove.
      x2 agreed dont try anything else until ur confident with ur abilities i can take all 4 panels off in less then 10mins
      Summer 11' Big plans (Bodywork/paint/rims etc..) in Progress STAY TUNED
      CLICK THE PIC
        Unless you do not have power locks at this moment(own a dx) then a keyless entry install has nothing to do with the door. You would want to pay someone to install it because you would do more damage then good.
          Well the thing is that Ive only owned my cb for about a month, and my power door locks dont work, so i kind of figured that it was the control box/relay inside of the door, so i was thinking that if the door panel needs to be removed to have keyless entry added, well then i might as well take it to my audio guy with the door panel already removed, and its not that i think its very hard, its just that i dont fancy removing my door panel multiple times
