Dome light
    Dome light
    So the dome light doesnt work at all.On/door,i tested it to have no power, and the fuse is good.Has anyone run into this problem before?
    90 Panda DX F22A6
    bump, i need light!!!!!
    90 Panda DX F22A6
      Did you check the bulb? (I ask because you mention the fuse but not the bulb) All door switches? Check them for continuity as well.
        you may need to run a new +12V to the light. It has a constant 12V feed, and the ground is switched to the door pins.
        check the bulb.
        is there power between the fuse and a body ground?
        is there power between the 12V in the light to a body ground?
        does the "ON" ground have continuity?
        try running a jumper cable with +12V to the light to see if everythig acts normally.
        My Rides:
          I had the same issue and thought it was just that it didnt work @ all.. picked up a 75cent bulb for the dome - inserted and Waaa.laaa -
          Check Out My Work In Progess . . . . .
            i tried a new bulb , wasnt it. Im gonna check the wiring later. I got a new deck with a USB on the front of it, and i plug my USB flexible laptop light in if i need light.
            90 Panda DX F22A6
