need help raido problem
    okay so my speaker wire was loos. so when i took the deck out to check the wires, i reconnected then all. put the radio back in ( wires connected right and all..) no power to the radio. so i try d connecting the yellow(battery wire) with the red(ignition wire) and it turned on. BUT no memory what so ever! radio don't save nun of the setting and even the dash clock don't save the time...
    Any Ideas?
    heyy i got the same problem !!!! lol
    lets wait for the experts to chime in an inform us
    I sell slightly used tires for cheap, jus pm me what u need!
    Hp sells cars, Tq wins races ....
    - 95 Camaro (beast) TOTALED
    - 92 Camaro RS (fixer-upper) SOLD
    -92 Accord LX (slammed) SOLD
    - 95 Jetta (VR-SEX) CURRENT DD
      check fuses. under hood and under dash.
      simple
      Retro!
      Hater
        its not fuses cuz i get power(and cuz i checked all of em), i just don get memory... an if i hook up my REM wire from my amp to the memory wire on the car harness i get nothing so i have to hook it up to the 12v wire....
          ur fuse.
          check under the hood....7.5 amp "backup fuse"
          also check the 10 amp "radio fuse " in the car
          also check the "interior light" fuse under the hood.
          Retro!
          Hater
            The power wire is different to the memory wire (Power wire live in Acc position, and Memory wire always has constant power) As accordztech said - check your radio backup fuse.
            And if it blew, then there might be another issue causing it to blow.
            My 5.7 LS1 Holden Ute
