The "Big Three" Question
    I know the bigger, the better. So I'm going big
    But what type of wire do I use?
    Solid Copper
    OEM Type wire
    Amplifier type wire (like Monster, Scosche, Tsumani...etc)
    Your man for wiring solutions!
    CB7Man's Coupe H22 Swap
    CB7Man's Sedan Resurrected From The Dead
    amp wire, at least 8 guage. i use 4
    FA1
    355
      Solid Copper
      OEM Type wire
      Get the cable with the highest number of strands you can afford. More strands = higher efficiency, which translates into better grounds and more power to all the car's electrical systems. Typically, high performance audio cable like Monster Cable or similar brands will seriously outperform OEM cables. This is why grounding kits are so effective.
      ~If everybody you knew jumped off a bridge...the bodies would pile high enough to break your fall if you jumped after them.~
      Project Deerslayer
      UPDATE: DEER - 2, CB7 - 0
      '93 EX 5-speed coupe
      Short ram intake
      Tenrai Himoto catback
      Smashed front end
        you can buy a capacitor wiring kit at best buy for about 15 bucks. it comes with 5ft of positive and 5ft of negative power wire. that should be plenty to do your grounds. its high quality, high strand count, extremely flexible. its made by rockford fosgate.
        thats what I have on mine, go with the 4 gauge, you will be fine. unless your runng 0/1awg wire, then you need to match up the wire size to what your using.
        Member Ride Facebook
        XBOX LIVE = RedDragonsFool
        SOLD MY CB JUNE 16, 2009
        For Sale Thread
          go big or go home!!!
          Members Ride sold...
            x2
            For Sale Thread
              +1 on the fine strand copper wire.
