CB7 Wiring
    CB7 Wiring
    I copied this from a wiring site I use for work. I see a LOT of posts asking for wire colors for alarms, door locks, mainly to wire a radio. Well here it is, the last time I'm posting it. Sticky it, learn it, save it, copy it, do whatever with it.
    Audio/Mobile Video
    WIRE COLOR POLARITY LOCATION
    Battery WHITE/YELLOW (+) RADIO HARNESS
    Accesory YELLOW/RED (+) RADIO HARNESS
    Ground BLACK (-) RADIO HARNESS
    Illumination RED/BLACK (+) RADIO HARNESS
    Power Antenna YELLOW/WHITE (+) RADIO HARNESS
    LF Speaker (+) BLUE/GREEN
    LF Speaker (-) GRAY/BLACK
    RF Speaker (+) RED/GREEN
    RF Speaker (-) BROWN/BLACK
    LR Speaker (+) GRAY/WHITE
    LR Speaker (-) BLUE/YELLOW
    RR Speaker (+) RED/YELLOW
    RR Speaker (-) BROWN/WHITE
    Amp Location IF BOSE AT EACH SPK
    Radio Security YES
    Security
    Battery WHITE (+) IGNITION SWITCH HARNESS
    Ignition 1 BLACK/YELLOW (+) IGNITION SWITCH HARNESS
    Starter 1 BLACK/WHITE (+) IGNITION SWITCH HARNESS
    All Door Trigger BLACK/WHITE (-) ABOVE HOOD RELEASE "BRN PLUG"
    Trunk Trigger GREEN/BLACK (-) ABOVE HOOD RELEASE "GRN PLUG"
    Hood Trigger N/A
    Alarm Disarm N/A
    Parking Lights RED/BLACK (+) AT FUSEBOX IN DRIVER'S KICK
    Convenience
    Headlights-Lo BLUE/RED (-) AT LIGHT SWITCH
    Wipers-Lo BLUE (-) LEFT OF COLUMN "BRN PLUG"
    Trnk Release ORANGE/SLV DOTS (+) IN HARNESS DRIVER FRONT DOORSTEP
    Remote Start
    Ignition 2 WHITE/BLACK (+) IGNITION SWITCH HARNESS
    Accessory 1 YELLOW (+) IGNITION SWITCH HARNESS
    Anti-Theft Descript NONE
    Key Sense BLUE/WHITE (-) IGNITION SWITCH HARNESS
    Neutral Safety GREEN/WHITE (-) 12 PIN CONN GEAR SELECT SWITCH
    Tachometer BLUE (-) AT DISTRIBUTOR
    Speed Sense ORANGE (AC) LEFT FENDER GRAY 6 PIN PLUG
    Brake Lights GREEN/WHITE (+) AT BRAKE SWITCH
    Reverse Lights GREEN/BLACK (+) 12 PIN CONN GEAR SELECT SWITCH
    Horn LIGHT GREEN/BLUE (-) AT STEERING COLUMN
    Modules
    WIRE LOCATION
    Please select another category
    Doorlocks/Windows
    Power Unlock BLACK/RED (-) NEGATIVE TRIGGER
    CAN BE FOUND IN A GRAY PLUG WITH BLUE TAPE AROUND IT IN SOME VEHICLES.
    PowerLock BLACK/WHITE (-) UNDER THE CARPET BELOW FUSE 2 PIN PLUG
    LF Window Up LF:RED/BLUE
    RF Window Up RF:BLUE/YELLOW
    LR Window Up LF:RED/YELLOW
    RR Window Up RR:YELLOW/GREEN
    What you do with this is none of my business, nor am I responsible for any mishaps or havoc you create when using them.... unless you do something totally cool. Then its all me.
    Edit:
    I forgot to mention, if you are going to be using this as a guide to wiring in your cb, make sure that you test the wires first. These are known to be wrong here and there from time to time. This one is very spot on but remember shit happens. Just use a multi meter or a test light before you use the wire and make sure its actually the one that it says. With that said, good luck.
    Member Ride Facebook
    XBOX LIVE = RedDragonsFool
    SOLD MY CB JUNE 16, 2009
    For Sale Thread
    bump. i cant believe no ones even posted on this yet with all the wiring requests I see.... maybe I should put it in the noob section?
    For Sale Thread
      haha well i already have acces to this .... but its nice to have it here.....
      Members Ride sold...
      I'm back...... with a coupe. oh boy here we go.
        lol I posted it for the people who dont have access to it. but apparently the only people who pay attention to it are the installers.
        For Sale Thread
          it needs to be stickied lol so that way ill just come here lol
            haha, seriously, that would be cool to have something stickied that I wrote, seeing as everyone and their mom has something stickied already.
            For Sale Thread
              sticky this bitch!!!!
                I motion for a sticky icky icky
                My swap thread
                Main relay proplems?--DIY
                  nice find.......sticky it.....
                  My Cm7
                  My Cb7 (DD)
                    Yay my first sticky!
                    It's no find, thats off one of the 4 websites I use for wiring diagrams. I also have a number for best buy installers that I can get detailed wiring for damn near any vehicle.
                    For Sale Thread
                      some of that info is mixed up. for stereo wiring the negative speaker wires have either black or white tracers and the positives have green or yellow.
                      and as far as i can remember the starter wire is black/white but i could be wrong on that one.
                      FA1
                      355
                        that wiring is at the deck's harness. the speakers maybe the same at the speaker but I can't remember clearly. I used this wiring when I did my alarm so it should be right see'n as I have a remote start. Regardless this chart is just a guide, you should always test a wire before you use it. I suppose I should post that up top which I am going to do now.
                        For Sale Thread
                          okay i have a quick ? does has any one heard of having to obtain a code for when u unplugg the battery...b/c idk if my friend is just messing with my head about that...he says u need a code for it or things will not work anymore....soo this has made me back off of doing my own stereo install
                          ~CB7 Phoenix~
                          (picture missing help me get a new one )
                          The California White Tux
                          *and its alive!! hahaha*
                          *under construction*M.R.T: http://www.cb7tuner.com/vbb/showthre...=1#post1689652 *changes soon to take over*
                            only if your factory stereo codes. if your putting in a new stereo dont even worry about it.
                            For Sale Thread
                              /\ he is messing with you no code is needed
                              Maple50175 - you're annoying =P
