Try www.mequiars.com or 800-545 3321 The site has a media presentation that goes through the "steps" for keeping your car clean. BTW a friend put clay to my hood (bonnet to some of you) because I was so pissed about having sprinkler water drops on it over the years and could not remove them. The clay bar removed them and the hood was Smooth and Shiney! Never will I use home soap and bucket, or inferior wax again!
Thinking about Clay Bar and general waxing questions
Old wagon - Silver '92 LX Wagon - Steve (Shadow)- STOLEN ON LABOR DAY 2012
New wagon- White '92 LX Wagon on 1/3/13 (Frostbite)
2000 EX Coupe - Joe -
www.AccordWagonClub.com
My Facebook Site - ACCORDOBSESSION
So I used Mother's Clay Bar system on the hood of my GF's car over the weekend. I used the spray liquid and clay and it didn't really take anything off. I guess the hood was pretty smooth to begin with, so I'm not sure if it really needed it.
I sprayed the lubricant and then rubbed the clay bar up and down, then left to right on the hood. Did I do it wrong, or use too much lubricant? I had to clean the hood again afterwords, because there was kind of a haze on the hood afterwords. Hmm.
If the paint was already smooth=clean it won't make it any better. If not it should have removed dirt. I have heard mixed comments about the Mothers brand of clay. I haven't used that brand myself, but can verify claying works quite well for paint and glass.
Did you spray the clay and the car's surface then clay, and spray again and wipe off?'92 Accord LX Sedan--Bordeaux Red Pearl --OEM--279k Daily Driver
EX Lip & Alpine OEM single CD Player. No more useless pocket!
Originally posted by doylnaI sprayed the lubricant and then rubbed the clay bar up and down, then left to right on the hood. Did I do it wrong, or use too much lubricant? I had to clean the hood again afterwords, because there was kind of a haze on the hood afterwords. Hmm.
Really not necessary to change directions, I typically keep going in the same direction so that any scratches I might accidenatally create will be easier to remove. The clay isn't abrasive, but since it does pick up contaminants, you're left with the potential to drag abrasive elements across the paint... best way to avoid it is to knead the clay every section or so.
Mother's clay is a lot tackier than ClayMagic so if you weren't feeling a little bit of resistance against the paint, then you probably were using too much detail spray. I find it to be an easier gauge with mother's if you leave the car wet after a wash and then use a minimal amount of detail spray.
You should always wash your car after claying, because clay will leave behind some residue from breaking down as you use it. Polishing can take it off as well, but it's best that you wash it first so that you don't gunk up your polishing pads.
Originally posted by mrvinyl33If the paint was already smooth=clean it won't make it any better. If not it should have removed dirt. I have heard mixed comments about the Mothers brand of clay. I haven't used that brand myself, but can verify claying works quite well for paint and glass.
Originally posted by 93LoProLXReally not necessary to change directions, I typically keep going in the same direction so that any scratches I might accidenatally create will be easier to remove. The clay isn't abrasive, but since it does pick up contaminants, you're left with the potential to drag abrasive elements across the paint... best way to avoid it is to knead the clay every section or so.
Thanks for the hints. I'll give them a try on my car this weekend.
