fast blinkers?
    fast blinkers?
    well i cut and changed my harness's to the H4 balb, but since on my new jdm lights theres only room for either the parking corner or the blinking corner, i unhooked the bilnker for both sides and just used the parking one,
    but now my blinker on the inside of the car is like a rave it blinks so fast, also the taillights r blinkin that fast, is this bad?
    just plug the blinker bulb back in and tuck it somewhere. and what do u mean ur tailights are blinking?
      well when i use the turning signal the blink is reallly fast and on the dash its blinking really fast unlike before,
        the car thinks one of the bulbs is out and the fast blinking is to let you know that, as stated above leave the bulb in and stuff in somewhere.
        (or maybe your low on blinker fluid )
        FA1
        355
          yea^^ go to advance and ask for 93 accord blinker fluid, that might help
            The flasher is looking for the combined resistance of all of the bulbs in the circuit, that's how the flash rate is regulated. This will NOT harm anything, and if you want to slow the flash rate down you can either plug in the extra bulb and hide it, or solder a resistor between the + and - of the vacant plug to emulate the resistance of the "now missing" bulb.
            You can also purchase newer flashers that will flash at the same frequency no matter what the resistance of the circuit!! (like LED flashers)
            1992 Accord LX - SOLD
              ok what maroonaccord2.2 said partially true but i wouldn't recommend doing it until you hear me out.
              you have installed the headlights correctly. in the process it is possible that a main signal bulb went bad (probably one of the bumper lense bulbs). when it's blinking fast, that means that there is a bulb out but the flasher/relay only needs to see the 4 main signal bulbs (two in the rear tails, and two in the front bumper). the little corner wedge bulbs have no affect on the flasher/relay at all! i'm almost positive that you have a busted main signal bulb. hit the hazard button, step outside, and check around for any busted signal bulbs (with exception to the corner bulbs). again the corner bulbs don't affect the blinking rate.
              if all are working then do what was suggested above. good luck!
              1cor10:31
              - 92 LX coupe
              - 96 EX wagon (sold)
                i like the fast blink
                  ONE of your light bulbs blew out
                  ・オレンジ(デミオのオレンジがなかなかいい味を…)
                    ・ブルー(インプレッサみたいな感じのメタリック系が何
                    ・その他随時考え中…
                  ......今日までの道の愚かな米に屈辱を与えるためにHonda Accord は作られた。愚かな競争を従事させている間抹消されるところ倍数の敵ターゲット。CB7 Honda Accord 。道の王。自動車恐怖。........
                    Fast Blink
                    I am having the same fast blink problem I Have replaced all the bulbs with new ones but still get the fast blink. I have not done the conversion yet. Still with every thing original and all new working bulbs on my 90 Accord I am getting a fast blink.
                    I My Honda
                    Check out my Ride Here
                    09-11-01 NEVER FORGET
                      One of your bulbs are failing. Check them all and make sure that you have clean connections. If you changed nothing but have fast blinking then one of your bulbs is not connected securly enough. I dont know a better way to put it
                      WHY ARE HURRICANES NAMED AFTER WOMEN? CUZ WHEN THEY CUM , THEY ARE WET AND WILD AND WHEN THEY LEAVE... THEY TAKE YOUR HOUSE, YOUR CAR AND YOUR MONEY....!
