today i tied my bumper lights into my parking lights. now my turn signals dont work. I checked the fuse and it looked fine. what should i do?
turn lights out help
are you trying to wire up the bumper lights to stay on with the parking lights? if so, what you did won't work meaning your lights won't blink either. you need to use a relay to make them blink. there are other threads on how to do this, as well as other methods.
or are you saying that after you wired them, your blinkers don't work at all? if that's the case, then it is your relay that shorted out. it's located under the dash on the driverside. you'll need to hit the hazards to hear it click to know which relay it is. that is if it still works. good luck!
