Okay i really need help adjusting and stuff for my headlights because im not getting a good light span like some of you guys i see on here with USDM headlights. For some reason my light beam pattern is like cut off in ways and its not spreading equally and giving me good visability even with Sylvania Silverstars. I want a beam pattern kind of like this
Headlight Beam Pattern
aiming lights correctly
in a level parking lot with a perfectly perpendicular wall:
park your car with your bumper as close to the wall as possible (be careful)
with a tape measure, measure the distance from the ground to the center of your low beam reflectors on your headlights. subtract two inches from this measurement and mark it with a piece of tape on the wall. do this for both sides.
the pieces of tape should also be located where the headlight 'flares' start on each side when your headlights are on when parked next to the wall
now back up your car (straight!) about 25 feet. put a t-shirt over your passenger side headlight
aim the drivers side headlight so that the 'flare' is aligned at the spot that your marked off with the tape...do the horizontal and vertical adjustments.
now put a t-shirt over the drivers side headlight and repeat process for passenger side...you can also aim the passenger side headlight an inch or two higher for better illumination
Good writeup! Thats exactly how I did it.....it works great!1991 Honda Accord Ex
Pics of the beast!
::::198.4 WHP and 146.6 WTQ Currently weighing in at 2700lbs...best time: 14.8@92mph::::
2003 BMW 330I Sport.....Daily Hustler....
Road Race #1
Totoro Squad #2
I used a screwdriver, it sounds to me like your adjusters are stripped or something.....1991 Honda Accord Ex
Pics of the beast!
Road Race #1
Totoro Squad #2
Originally posted by srsskylineoh like u stick a lil flat head in and just twist back and forth right ye mine still works1991 Honda Accord Ex
Pics of the beast!
Road Race #1
Totoro Squad #2
u used a phillips and stuck it in the hole? or did u adjust the 3 phillips on the outside of the clear plastic thing? and when u push in on hte highs a white knob comes out and u can adjust it easier but i did that on the passenger side easily but on the driver's side i can't because a hose is in the way, i think the easiest way to do it is take the headlight off or something then adjust it. I duno how u got urs to work...
Does anyone have any pictures to show what white knob they are talking about? i am trying the adjust mine too, but the only adjustment screw that i see is the big one that uses a phillips screwdriver to adjust. right now my lights are like this : / l and lights up the road probably 4 feet infront of the car.
well i just recieved a set of hid from my brother. fro free they came out of a bmw not sure with model. i know the bulb does not fi extactly on the hole for the stock 9006 but i got them to stay in. but when i turn on my lights i have a beam all over the place. iam blinding they shit out of people and they have asked me what kind of bulbs i have. so my question is does that methos work with the usdm head light or are the bulbs not put in correctly.
Originally posted by dynamic93well i just recieved a set of hid from my brother. fro free they came out of a bmw not sure with model. i know the bulb does not fi extactly on the hole for the stock 9006 but i got them to stay in. but when i turn on my lights i have a beam all over the place. iam blinding they shit out of people and they have asked me what kind of bulbs i have. so my question is does that methos work with the usdm head light or are the bulbs not put in correctly.
Those bulbs are not ment for reflector housings, They are ment to go with projectors. Just get yourself some better bulbs and call it a day. You are only causing problems glaring the shit outta people.
Originally posted by bruno8747You are only causing problems glaring the shit outta people."This truck is 100% sh*ts and giggles."
"Speed has never killed anyone. Suddenly becoming stationary... that's what gets you." Jeremy Clarkson
You're not JDM until you have a car built in ohio with tons of bolt ons from ebay.
Disregard females, acquire currency
BUS 62 AIN'T F'ING AROUND!
go get a set of projectors from a bimmer and fit them in, they wont look so sick after someone elses car gives you a drop kick in the face. , don't glare ppl man it just causes problems, also light doesn't do that good if its spread out like a easy... lets no go there... fix the glare to be considerate for drivers out there.1990 Accord EX -Stock to no beyond
Originally posted by yeamans17you'd better soak the nuts in pb blaster, otherwise you'll snap them off
Vouch - | gloryaccordy | aznkid.com |
