Lighting problems any suggestions?
    Recently my headlights have decided to work when they feel like it i notice that when this happens the signal light in the gauge cluster remains on but its very dim, the bumper signal aswell as rear signal also stays on while the other side works fine. I recently installed oem foglights but had the wiring kit in the car for over 6 months and have never had this issue this has started since i installed the oem fogs do u think its maybe bad grounding thats throughing something off? But i cant see how this is possible since the wiring kit was never hooked up to the headlights. But when my gf's dad taped the wires going to the fog relay the headlamps went on and all was fine, it did the same again the next day i tapped the wires to the driver side bulb and they all turned on again i really need to fix this problem its only my lowbeams that do this the highs remain functional.
    My Cb bad, Cb bright and the cops can kiss my Cb lights - I’m gone!
    Frost White Member 13
    My Ride
    "Girls are like a new car... lease w/ option to buy"
    i dont really know the exact problem but as u stated it looks the same thing happend to mine before...when i hit bumps i turns off..try fixing the wire that poweres the bulb..but as i said i dotn know...hehe...but yeah hope that gives u an idea..
    Fast and cheap won't be reliable
    Cheap and reliable won't be fast.
    And fast and reliable won't be cheap
    ~EYCEE~
      my suggestion is to use new sockets for your low beam and ground them correctly. Use one of those wire coverings that you get at autozone or something to wrap around your wires that hold positive charge cuz live wires create a charge around it and can sometimes mess with other wires that are in close range.
