I just brought a pair of 9006 xenon light bulbs and I can't install them in my 92 accord without removing the headlight. Does anyone know how to remove it.
headlight help
you dont need to remove the headlamp to put new bulbs in
there is a twist lock (black or grey ring) around the bulb
after you unplug the old light bulb(s) twist this ring
i cant remeber if its clock wise or counter-clock wise (i have JDM lights now)
but once you twist that ring the bulb should just pull right out
if you never replaced a bulb befor it can be realy hard to get it unlocked for the first time
if someone remebrs the thread there is one that tells how to do this and tecknieqs they used
do a search you might find somthing
spin them counter clockwise...if this is the first time youre chaniging your bulbs then it will be hard cuz its going to be stuck...what i did is slide a flat head screwdriver in the little slot that thing has and gently tap down...it will spin it enough to loosen it and you could take the bulbs out. good luck
Originally posted by fizzbob7first off, don't be a sissy bitch.....that's what you're beingOriginally posted by ACC0RD22no need to get sand in your vagina over this guys.
if he has the aftermarket ebay projectors hes goign to need to take the headlamp out to raplace the bulbs.. some of the aftermarket shit is like that, now if its oem and you think you need to remove your wrong you just twist the black piece and it will be hard as fuck the first time if u havent changed the bulbs before, warm the headlights up first it will make the plastic piece softer and easier to move, otherwise it might be just stuck. and take hella work..Last edited by 93accordEX; 01-01-2004, 03:59 AM.
Anyway...I was gonna kinda ask a question similar to the first guy. I know that I don't need to remove the headlight to put the new bulbs in...but how do i replace them? In my owners manual they just happened to do every light but the headlight. Here's a pic... It's the drivers' side. I think i can do that one...but on the passenger side there's the battery and stuff in the way. HELP!
Thanks!Last edited by ProjectCB7; 01-01-2004, 02:16 PM.+ '93 Accord EX - CB7 - Frost White w/ Dark Blue = teh s0ld (ilikebigbutts)
. Snail Squad .
thanks!
what way do I twist them? I just want to make sure so I'm not tightening them...
do you need to pop something out THEN turn them?Last edited by ProjectCB7; 12-31-2003, 10:42 PM.+ '93 Accord EX - CB7 - Frost White w/ Dark Blue = teh s0ld (ilikebigbutts)
. Snail Squad .
