Okay i install my indiglo gauges but don't know how to power them.....all there is, is a red and a black wire i just don't know where to put them. I know there is a bulb in the back of the cluster that has a wire connected to it, do i splice those wires and connect it to them, and if so is there a specific wire that goes to the red or to the black...cause both of the wires from the cluster are gray.....if anyone can help i'll appreciate it...thankyou!!!!
indiglo gauges wiring HELP!!!
run the wires down to the dr kick panel fuse box.
for the black wire go to any metel ground spot
for the red put a fuse (prob. 10 amp.) in line and connect it at the fuse box-- remove the fuse cover just above the fuses theres 4 flat blade terminals recessed in a square holes. use a multi meter to test wich one has power when the park-headlights are on, and none when off..it always has 12 volts when on, i think its the 3rd one back. its where they tap into the park lights for alarms ..i think the other ones are like-constant- ign-acc.
dont go off any light that is hooked up through the dimmer switch, for it could lead to probs.
hope it helps
91 ex 1badwag
91 lx wag (aka the beater)
92 ex 4-door
HONDA...its not just a way of life...its an ADDICTION!!!!!!!!!!!!
