Turn Signal Question
    I, like some of you tried to do the running bumper lights by just connecting straight to my corner lights which ended up messing the corner light. I have one side that works and one side that doesnt. The bulbs are fine and so is the connector but it still wont work. Did anyone who did this and had the same problem figure out a way to fix it??
    1991 Black Accord Coupe
    Sprint Lowering Springs
    Neuspeed/Koni Sport Shocks
    Suspension Techniques Front and Rear Sway Bar
    17" Motegi DP6 with Bridgestone Potenzas
    TSX HID Retrofit with 4300K Bulbs
    http://www.cardomain.com/id/sthrnba711
    i triyed the same thing but wen i hooked it up i went to try it but neither both corner nor bumper light up once i disconected the bumper wire the corner worked again some one hiit us up
      I tried replacing the bulb and socket but thats not the problem. The bumper light works fine and the passenger side corner blinker works, just not the driver side i tried to rig up. Any help would be awesome.
        im guessing you guys are trying to do this for the 1156 bulbs... for it to work i think you have to do a relay to retain the signal and the light itself... or just do the 1157 bulb conversion that would be easier..
          u may have damaged a circut. check fuses and relays.
          when you test blinkers, listen for a ticking, if present relay
          is good. maybe you dont have the correct polarity(+ -)
          or amps,watts, ect. hope to help some. i don't know if i
          have seen you in alpharetta, maybe i will soon
          Avoiding dirt at all costs
            I have what I think is the only Black coupe in Alpharetta. Its a 91.
              i also have a 91 but it is cobalt blue.
              most people think it is black at first.
                Is it a 4 door, that looks slammed?
                  About the lighting question. I got the wires connected correctly and the fuses are fine. I found the relays but how do i know which one it is. There are like 6 or so on top of the fuse box inside the car.
                    it is a 4 door and slammed dark tint and says flat line on
                    windsheild. there should be a diagram saying what they
                    are for, but if u turn on your blinker and here a tic toc
                    under the hood they still work. try putting it back to normal
                    see if that works if it don't then you know u got a prob.
                    i once saw a person hook led washer nozzels to their turn
                    signals and it blew something
                      do the 1157 bulb conversion. get a light bulb plug from the tail lights of a junked accord, and use that harness to hook everything up.
                      --JDM F22A--
                      JDM schmeDM, these lights are DIY-DM.
