I got my running light to work now... Its pretty much like the setup of accordztech... thanks man... But I did the diode and it still didnt work so i just cut some wires here n there and grounded it and boom it worked.... So now i can use all my lights yay... Ill post some pics soon if I have a chance...
i guess ur setup is like mine, technically the diode did work, now u have high beams that are independent...you basically have my DRL setup. but i think i raun another wire to ground it...i believe i grounded the positive signal..not sure exactly.
yea but i didnt do a switch for relay or drl kit i used our regular headlight switch ... so when i switch to high beam and go to parking lights i have highs as driving lights alone and if i go to regulart light switch i have lows as regular driving lights and if i hit the high beam switch again both sets turn on at once
