Running Light Question
    I have a problem with my drl kit... I installed it on my high beams to make it turn on 50% off but then it worked right.... then a couple minutes later my high beamed didnt work as drl anymore and suddenly low beam works... so overall i installed drl kit and tapped the high beam wires and somehow SOMEHOW low beam is on drl now... its weird cuz high beam did work as drl but then didnt and switched for low beam.
    USDM or JDM headlights?
      jdm projector one of those ebay ones...
        you need the dual filiment h4s in order for them to work properly... im not sure how accordztech did it with his usdm headlights.. he never did show us.
          cause it was a pain in the ass...and still is...lol im wondering how i did it
          the thing is i was talking to him and he said he hooked it directly to the h1 high beam. im thinking he can use a 6 ohm diode inline so that power wont feedback the other way...thats one step i used to get my DRL's to work, thanks to cpmikes advice.
          Retro!
          Hater
            well the funny thing is that i talked to cpmike and i told him i just did a diode on it and he said its a good idea and i did it and it still the same thing... i used a 12volt zener diode from radioshack.
              ok dude thats now super weird, did u put the diode on right..the silver strip facing the right way? i think facing towards the bulb, and did u put the wire from the drl unit after that diode??
              Retro!
              Hater
                oh make sure its a 6a diode at least, those are the bigger ones...cause if not it wont work.
                Retro!
                Hater
                  Are all of you using the insight drl kit? Ive been watching ebay for... quite a while, and nothing.
                    yea insight kit... the seller sells them pretty quick he usually put it up for like only 5 items at a time and he'll start selling more like in a couple days or so...
                      I got my running light to work now... Its pretty much like the setup of accordztech... thanks man... But I did the diode and it still didnt work so i just cut some wires here n there and grounded it and boom it worked.... So now i can use all my lights yay... Ill post some pics soon if I have a chance...
                        Here are some pictures...
                          here are some more
                            looks good. Kmart got me hooked on the DRL's so one day i'll have a set.
                              What yellow bulbs are you using? those look hella yellow, more then my lumnics ones..
