Ok I followed the instructions on hooking up the oem harness, hooked everything up turned on my headlights and pushed the fog light switch and it doesnt turn on.(there's no light from the switch itself)
Is there any way to rule out a piece of the harness that might be bad. Like if the relay was bad would it atleast turn on the fog light switch light? I double check my grounds and they're good. My only guess with out knowing if the relay would cause it to not power up is that the switch is bad. I'd rather not go and buy a new switch without knowing for sure if it's the cause. Is there anyway of testing it or testing any of the parts without replacing? Yes I also checked the fuse it's still intact will be replacing it when I get off to rule that out. Just figured I'd ask before I embark on the journey.
