i am at the stage where i have to connect two plugs into #3 and #5 connector.
the problem is that there is already plugs at those locations. i think it is the viper alarm (im not sure)
now dont know what to do.
please help, homes.
i already did some searching-
CPmike-
new diagram looks good, and i might just want to mention that starting from the rear end of the car, moving toward the firewall, the four 12v power pins in the driver side fuse box are:
1 - accessory
2 - ignition
3 - parking lights
5 - constant
so the "switched prong" that timmy is talking about is the third pin to the right, #3. this will only allow the fogs to be on when the headlights are. as another option, hooking up to the #2 pin will allow you to turn the fogs on any time the car is running.
__________________
Ejx_micheal-Look at the underdash fusebox. See the 1 pin connector near the top with the large white wire coming out of it? Unplug that and move it to the plug a on the far left of the fuse box thats a little higher than the others. Now the fogs will only come on when the ignition is in the Acc or run positions.
please help, homes.
CPmike-
1 - accessory
2 - ignition
3 - parking lights
5 - constant
__________________
