fog lights for a 92 ex coupe
    Do these fog lights fit on a coupe bumper because it says sedan bumpers only but i wasnt sure if these would fit on my bumper. if not which ones do i need. thank you
    http://cgi.ebay.com/ebaymotors/90-91...mZ200612637965
    http://www.cb7tuner.com/vbb/showthread.php?t=194049
    Yes the bumpers are the same between coupe and sedan
      ok bro thanks i appricate it
        Although i just noticed
        You asked for a 1992 coupe? Those foglights are for 1990-1991 accords. They will not fit a 1992-1993
          Also there isn't any information on the harnessses and the switch. Which probably means that he is not including them. But if you want to buy them anyway it's up to you.
            wtf is a winker?
            COUPE K24
              Originally posted by '93CB7Ex View Post
              wtf is a winker?
              Idiot speak for turn signal
                300 dollars they're smoking big crack, but I guess it doesn't matter anyhow cuz they ain't fitting on your 92 coupe regardless.
                  300 is a little high for them. you can usually find a set on here for between 100 and 150 shipped. as far as the harness, its pretty easy to make your own with a relay and it will actually save you money. as long as you can get the switch and the fogs with brackets you'll be good to go.
                  click to see my ride
                  click to check out my bb6 dash swap
