Which HID setup to use
    Which HID Kit is the best to use and could i use them in my headlights without having to fit a projector in there? Also has someone done a write-up yet on how exactly you wire all this together?
    My Ride
    myspace
    you dont need a projector..
    if you have OEM housing you need a 9006 capsule.
    projector housing = h3
    jdm housing = h4
    ill write more when i get out of class..
      Hm...well I am assuming that you already used the search feature using HID* as your search word. Most HID kits are plug and play though and come with all necessary wiring and even instructions. You can use your OEM housing as rebels has described. Just make sure you get a 9006 HID capsule. Honestly though there are a number of HID kits out there. I had one at one point and it is much brighter than stock, but not nearly as luminous as my retrofit.
      "This is a jaded bunch. To gain notice, you have to challenge conventional wisdom, test assumptions, and ignore the naysayers."
      FS Part out thread koni/skunk2 suspension, jdm pole, HID retrofit, Tanabe exhaust
        true, but you'll look like a rolling stadium with flood lights everywhere and just blind on coming traffic.
        05' S2000 GrandPrix White
        93' Accord (Sold )
        JDM H22
        Port n Polished Int Mani
        Bored TB, maxed
        MSD 6A
        I/H/E
        no cat
          ive never had a problem with anyone flashing me cuz of my hid's and i have them on stock headlights...i love them. oh, and i have the catz hid kit
          Originally posted by fizzbob7
          Originally posted by ACC0RD22
          So. Cal OUTLAWZ
            Well, that's for two reasons, 1- most people have gotten use to HIDs being so bright and your average driver has no idea how HID lighting works, they just know expensive cars have them. Most think its a bulb you can buy at Walmart, and dont even bother anymore.
            2- scroll down to 90-93 Accord: http://faqlight.carpassion.info/car-tested-retro.htm
            93' Accord (Sold )
            JDM H22
            Bored TB, maxed
            MSD 6A
            I/H/E
            no cat
              if you adjust your lights correctly and install the kit correctly, you won't get anyone to flash you. you can also get the reflective shields that reduces the glare problem.
              i would say use the HID's in a stock housing or JDM housing.. don't use aftermarket projectors.
                i am running the vision x 9006 kit and i have not had any problems with glare or people flashing me. real simple to hook up just took 2 wires and that is it.
                www.rms-usa.com
                  what do you guys know about the McCulloch HID kits Also i read about the kalvin temps and i think i would like to go with the 5000-6000k kit. Any suggestions? Oh and does anyone know what temp. the Acuras run with the "purple" hue?
                  My Ride
                  myspace
                    All OEM manufactures, BMW, Acura, Cadi, Ferrari, Lambo, Mercedes, Ford ect use 4300K from Phillips or Osram/Sylvania. Anything above 4300K is worthless, you lose lumens the higher you go up in the scale. In other words, you won't see jack shit like you would with the 4300K. You would actually see better with the Slyvania Silverstars.
                    93' Accord (Sold )
                    JDM H22
                    Bored TB, maxed
                    MSD 6A
                    I/H/E
                    no cat
