Fogs on without Headlights?
    Is there a simple way to make the fogs independent?
    So that the headlights do not have to be on for the fogs to come on??
    This is a full oem fog setup FYI
    Click it.... You know you wanna
    Bought from:Joshy,H22WAGON93, nho93accord,90accordLXGUY,phantomCB7,Tommi
    either run a separate relayed harness with an inline fuse, from a switch to your fogs.
    or just tap the power wire from your corner lights, so when you turn your corners on, your fogs come on.
      Hmmm.. I need to make a harness that plugs into my oem guy as i dont want to ruin a good oem harness i was hoping maybe just a different plugin in the fuse box haha
        I bought an aftermarket universal harness off ebay to make the fogs independent.
        1996 Honda Civic LX 2009-2012
        2012 Kia Optima LX 2012-2013
          I guess instead of grabbing power at the interior fuse box i could go from the battery as im sure thats where the headlights overrule the fog switch.... hmmm
            Correct , BUT you can rewire to use the oem fog switch.
              True enough... I could... Hmmm.... well im gonna poke around with the oem guy and see if i cant just rewire where it plugs into my fuse box =)
