HID Projector DIY?
    HID Projector DIY?
    Hey everyone,
    I have some stock headlights, and have had them blackhoused and yellowed in the high beams. But I got some Audi RS4 HID Projectors for free from the Junkyard here in Washington.. Don't ask me why they had an RS4 when it could have been parted out, but anyways, there were VERY few things left on the car, I got the projector headlights.
    Now my questions..
    1. Does anyone know how much I cut out of my stock headlight to get these to fit?
    2. How do I secure them so they stay in place?
    3. How the hell do I connect the HID kit (H7/D2S) to our bulb connectors (9005?)
    I will also be updating this as I go along with a step by step DIY if anyone wants one
    check out hidplanet.com
    but you will need a set of d2s adapters that adapt aftermarket AMP plugs to the d2s plugs.
    to mount them you have to decide on a mounting method and use either long bolts or something to hold it.
    Hopefully it fits in there, im doing some e39's from a bmw in mine and I had to shave the shit out of the projector.
    go to the other site and see if the beam pattern is good enough to be even worth it.
    Retro!
    Hater
      Thanks for that help! I was going to try and long bolt them with a locking nut on the back to hold them on, and then JB weld them to make sure they STAY in place.
      I saw your headlight shaving. I also have a few seven series projectors and a set of ///M3 projectors.
      I got the FULL RS4 headlight for both driver and passenger for free, and got to view the beam pattern in a dark garage and they are FANTASTIC! thanks again for the reference
        check my sig. the pics are small. that is the hid retro I did to my van.
        http://www.hidplanet.com/forums/view...100&highlight=
        on that thread thats me, i put bigger pictures. you have to be a member but it shows you how I mounted and sealed my retro on my van.
        Retro!
        Hater
          this is a pretty advanced DIY, IMO you should have plenty of experience with fabrication before you attempt something on this scale or it could very easily end badly. the fact that you are asking these questions kind of shows that you dont yet have this experience. my suggestion is to get some headlights that you dont care about and try it on them first. i'm not trying to bash or flame, just offering a suggestion.
            I just did some poking around on HIDplanet.com and there seems to be no plug adapter from the H7 bulbs to the 9005 plug.. .anyone know where to get two of them?
              hey while you're here, upload all those old pics from your mercury villager hid retrofit onto photobucket so we can see the pics. I've been looking up doing that on our 94 quest. The light output on the stock headlamps sucks the dicks!
                I do have an extra set of STOCK headlight housings. I also have access to many other projectors so this is no worry..
                Thanks for the concern tho
                  on the other site its re-hosted. if you dont want to go there let me know
                  honestly the retrofit isnt too bad. As long as your patient then you should be able to do a nice retrofit.
                  Retro!
                  Hater
                    ok buddy click on my link in my sig, its bigger pics. I was to lazy to put IMG haha so just click on them =)
                    Retro!
                    Hater
