ok I got the lights on the bumper and I have the entire harness I have everything hooked up to the small corner light and both the turn signals I have the relay and then the wire going to the fuse box is conected and a 5 fuse in the blank location BUT they don't work!!!
intersection side fog help
yea all the easy stuff was labeled the connectors were one to the harness and one to the bulb on the turn signals and one set up to the headlight corner light the part I need help with is how many wires need to be going up to the fuse box? I do have it ground to the radiator support were the headlights are bolted just something small I know I'm missing... If anyone has a harness hooked up correctly if you can take pics or put up some easy to read drawings (not a big wire guy)
there is 2 plugs that i didnt know where they went until someone on here helped me. here is my old thread pic is on the first page but help doesn't come in until the second page.
http://www.cb7tuner.com/vbb/showthread.php?t=102391Maple50175 - you're annoying =P
Brandoncb7 - I don't mean to come across like an ass but I see why you irritate Aaron now.
JoshM - Crotch rocket = chick magnet.
Originally posted by prodh22accord View Postthese are the pics i'm confused about as you can see i cut the wire and connected it to the fuse boc on the second to right on the bottom row and put a 5 fuse in the blank spot where the cornering should go but they don't work so how do i hook this part up??? pics if you can please.Maple50175 - you're annoying =P
well I think the problem is similar to yours but where did you plug the connectors? This part was the end of the harness I'm guessing went under the fuse but I cut it and put the single wire in the large white connetor under the fuse. I came to the conclusion to plug it there due to ebay instruction in a different sale but at the end of his harness it had a wire plug not a connetor like ours so I tried it. The part in the pic is the part cut that white wire is connected to the rest of the harness. Still it doesn't work and this connector doesn't go anywhere.
Originally posted by prodh22accord View Postwell I think the problem is similar to yours but where did you plug the connectors? This part was the end of the harness I'm guessing went under the fuse but I cut it and put the single wire in the large white connetor under the fuse. I came to the conclusion to plug it there due to ebay instruction in a different sale but at the end of his harness it had a wire plug not a connetor like ours so I tried it. The part in the pic is the part cut that white wire is connected to the rest of the harness. Still it doesn't work and this connector doesn't go anywhere.
ok i used the connector which has 2 wires on it. i cut the other connector off since it was only needed if there was something already in the fuse box connector spot. i put in 2 15 amp fuses just in case and mine worked fineMaple50175 - you're annoying =P
Originally posted by prodh22accord View Postok I connected the white wire to the connectors as it was and found where it hooks up under the fuse and the other connector loose but why did you say 2 15s why two?? And where? Itstill doesn't work but be ause of the fuse thing. So the other connector connects no where? Wierd?Maple50175 - you're annoying =P
