ok i need h1 plugs for my jdm headlights. i believe this is the plug for the high beams. what car can i find the plugs on so i can get it from the junk yard?
what car can i find h1 plugs for my lights
Originally posted by charlie0882004 View Postok i need h1 plugs for my jdm headlights. i believe this is the plug for the high beams. what car can i find the plugs on so i can get it from the junk yard?
H1 is a foglight bulb and you can find them in most cars with foglights. The only factory car I know of that also has H1's is the BB6 Prelude (97+)
Originally posted by FDAccord View PostIIRC, H1 connectors are two wires that plug once into the bulb and once into the area that holds the bulb in(for ground). IMO You're better off making it from autozone. You can easily buy 9006 Male connectors and create a plug and play harness.
H1 is a foglight bulb and you can find them in most cars with foglights. The only factory car I know of that also has H1's is the BB6 Prelude (97+)Maple50175 - you're annoying =P
Brandoncb7 - I don't mean to come across like an ass but I see why you irritate Aaron now.
JoshM - Crotch rocket = chick magnet.
Originally posted by xprojectcb7x View Post
Originally posted by Tnwagn View PostThe H4 bulbs fit fine in the socket on the JDM Headlights fine, but the H1 bulbs are too small to fit in the high beam socket by themselves. So you need 2 bulb holders (one for each High beam bulb). This not only holds the bulb in place in the headlight housing, but also converts the connection on the back of the bulb making it similar to an H4 bulb
You will HAVE to get 4 H4 Sockets to connect to the back of the H4 bulbs and the H1 bulb holders (which have H4 connections on the back, minus the top post which is unused on the high beams)Maple50175 - you're annoying =P
Originally posted by xprojectcb7x View Postjust buy the conversion harnesses from passwordjdm, theyre 35 dollars. probably less than you'll spend in the long run anywayMaple50175 - you're annoying =P
ok i think this is what you are looking for.
first pic is of the H1 bulb in the bulb holder
second pic is of the H1 bulb out of the holder
the third pic is of the bulb holder by itself
Originally posted by charlie0882004 View Postman thats more money i didnt know i need the holders to. where can i get that? i need that and the plug wires? the only thing i got is the bulbsMaple50175 - you're annoying =P
