JDM CL7 Steering Wheel
    Anyone Know if there is any way to make one of these fit a CB?
    Arcadia Green Crew Member #9
    It is highly possible. If you have a welder, you can actually cut out the spline shaft from a 90-91 accord and basically "make" your own hub. On alot of honda wheels, there are only small spot welds inside the wheel itself. You can melt it out and then weld the accord spline section in it's place.
    I've seen this same wheel in a 92 civic hatchback so anything is possible.
    I am the Yakuza CB7!
    JDM 96spec H22A 178HP 149TQ
    "The JDM Fleet"
    1993 Accord Sedan - 2.2 JDM H22a
    1994 Prelude V-Tec
    1999 CL 3.0
    2000 Prelude
    2010 Accord Crosstour - 3.5
    1993 Mirage S Sedan - 2.0 4G63 Project Evo 2.5
    1994 Mirage S Sedan - 1.5
    1991 Isuzu Impulse RS - 1.6 AWD Turbo
    1993 Asuna - 1.8 "CDM Impulse XS"
    1993 Sentra SE-R - 2.0 SR20de
    1995 200sx SE-R - 2.0 Sr20ve
      looks cool.
        Well Damn if its only small spot I think I may just give it a shot. I should be able to wire up the airbag without a problem. Hopefully.
