Backseat storage compartment
    Anyone know how to get this out? I got a new lid for the storage compartment on the sides of the backseat. and tried unscrewing the oh shit handle and it still wont come off. Any ideas? Its a 93 Coupe
    Arcadia Green Crew Member #9
    Bump
      well you have to take the entire panel off on the back side there are like 4 or 5 screws holding it on and once you remove the screws you have to pull on it because it has those snap clips right under the window, removing your back seat makes this easier it requires two bolts for the side on the bottom and one for the bottom onthe back to remove the lower part of the seat you have to lift on the rear tilt foward and pull it out the are two tabs at the front holding it if you need I post some picks.
