Removing the two side pieces of the rear seats? how-to?
    Sup guys I have a 93 sedan, just curious...how do you remove the two side pieces (the trim cushions on each side of the top-half of the rear bench seat). I need to remove those to get to two bolts that'll let me remove the support piece that gains me access to the top of the struts (so that i can adjust the dampening on my koni yellows)
    thanks
    My members ride thread
    There should be a bolt at the bottom, might have to lift the rear seat. Then you pull it upwards really hard, it'll be stuck in there pretty tight. I had to do same thing to get to my koni yellows.
      there should be a 10mm bolt on the bottom of the side peices.. you can get access to it if remove the bottom seat itself or by a ratchet with extension.. once the bolt is removed, slide the side piece up and towards you..
        thanks a bunch guys, i'll try it tonight
          Or you can do it with the seat bottom there. Just pull up and back on the top of it. Not hard because it is all foam.
          Gary A.K.A. Carter
          [sig killed by photobucket]
