Aren't those Amphenol pins intended to be crimp-type pins? (As in you use some obscenely overpriced specific crimping tool from Amphenol to crimp them).
I do own the expensive crimper your talking about but this is a little bit different style connector and thus uses different pins. The pins that i am using are intended to be soldered.
My Wiretuck/ Insane engine bay member ride thread 11.86@120mph T66 turbo 612hp F22A DIVULGE MOTORSPORTS
Finished my engine harness and mounted the connector to the firewall.
Bought all my missing bolts for timing side of engine....(took engine apart four years ago and half of the bolts dissapeared)
few pics of the engine
Bought a circuit works oil pump gear to prevent any unwanted oil pump failure. also recieved and installed BISIMOTO valve springs.
Looks great man, i wish i could do a tuck like that.
Wife: "Why do you get G power platinum and i only get V power?" Me:"Cause i have the high compression 93 octane only H22 and you have the bullet proof F22." Wife:........................"But yours are prettier" --------------------------------------------------- Wife:Baby, not everybody wants to do the 93 conversion" Me:YES THEY DO, THEY JUST DON'T KNOW IT YET.
Yea nopi is june 22 here in denver and im pushing hard to running and tuned by then. I only have my hondata and prologger to buy and im pretty much done. Just gotta figure out how to drain 10 gallons of c16 race gas out of my tank thats been in there for 4 years.
Nice progress... would be fun to play a prank on u like at nopi...just pull the ONE engine plug on the firewall and walk away... be easy 4 u 2 find but still would be great fun hahah....ignore me...
On another note..autoparts stores sells those lil siphon pumps... what I've done instead is get decent length nylon tubing... shove it into the tank.. And use a carb pump... will take a bit of time 4 ten gallons but it will work..... awesome project
that connector is great! it reminds me of the huge connectors they used for mobile video production houses. hope you have it up and running in time for NOPI.
they were not hard to solder because you pull the wire through a pin locator first then you solder the pin on and pull it back through. That way your not soldering in such a tight spot.
im not sure if ur talking about the cars gas tank, but if u are theres a 17mm bolt on the underside just unscrew it and make sure u have something that will hold all the gas.
93 Accord LX Sedan (sold)
yea but i dont have any way of disposing of 12 gallons of gas... thats my dilema
Bon Fire
that connector is a great idea so if something goes wrong with your engine just pull the plug and swap it all out
Maple50175 - you're annoying =P
Brandoncb7 - I don't mean to come across like an ass but I see why you irritate Aaron now.
JoshM - Crotch rocket = chick magnet.
