Uh oh how should i fix this? MAJOR RUST!
    i dunno if that is fixable. its the frame right?
    PSN ID's:Tidashoni
    1992 Accord EX Coupe
    My FS Thread
    Boosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
      rust is gone, sanded with 180 grit cleaned and primed ready for fiberglass
        oh, wow man. definately do not fiberglass that, its structural! if you dont know how to weld, either learn to weld or pay someone to do it for you. fiberglassing wont do anything other than make it look good, while making the frame no stronger. weld in some thicker sheet metal to make up for any stress on the other pieces that this may have caused. imo, that is almost enough to total it.
          x2!!!!!1111!!11
          F22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
          Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
          Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
            Buy the patch panel and have someone weld it in for you. It's a much better alternative.
            I can't really see that being structural, as the inner fender is still there, and that's the structure you should be worried about (I have a pic of my car without the quarter panel on it for reference), but I'd still get it fixed with new metal.
              hmm i guess i really should, im not that great at welding though. ehh i can do it
                wow that looks good so far. i thought it was possible keep the pics coming.
                Project EX Coupe Coming Soon...
                ..::Built not Bought::..
                  Yeah man, either welding or flush riveting. If you use a riveter with a bucking bar and aluminum alloy rivets, it'll hold good. You'd just have to add body filler and sand it smooth to get a good smooth surface. But riveting is hard unless you have the experience and the right tools. I'd pay a shop to weld it. And spray some corrosion X in that area after the work is done, that'll help prevent future rust. Corrosion X is good stuff , NASA even uses it.
                  H22 Fund Cancelled. Flight training underway.
                    the bumpers hanging right now, i painted it with black spray paint, so the primer wouldnt soak up water
                    when i get back to my rents house im going to just weld one piece of sheet metal across. and to the two sides. then put holes for the screws, and put it back on.
