Ok so three problems maybe four.
First: Windshield doesn't defog. I've noticed it especially when it is raining that even with the front defroster on, and blowing hot or cold air, it fogs up really bad and I wind up having to roll the windows down to get it to defog. And after a pretty heavy rain the other day I was driving around in, I noticed that alot of the windows inside were fogging up and was having to drive with the windows down so I could see in front of me and to the sides. but the rear windows were still fogged up except the rear because I had the rear defroster on as well.
Second: I've noticed moisture condensing in the tail light on the rear hatch on the drivers side. (not the part on the body, just the one on the hatch) I've also noticed a peice of the tail light near the top left has been chipped off. I presume this is where the water is entering from but not sure on that.
Third: In the spare tire well in the back I have noticed it's constantly damp in the bottom and the carpeting seems to have some staining on the underside that would suggest water leaking down into the car.
other things: After it rained I went out later and opened the rear hatch and water started dripping out of inner panel, also the top part of the rear hatch panel seems to be coming loose but it's not like flopping around, just doesn't fit snug against the lower part (maybe half inch gap). So water may be leaking in at the top of the door somewhere.
not defogging is semi-dangerous and extremely irritating. having a moisture filled tail light is just irritating the moisture in the wheel well is just puzzling.
anyone else with a wagon had any of these problems, and anyone else at all have any ideas how to fix this crap. especially the defrost issues so I don't have to drive in the rain with my windows down.
