I'm shaving my antenna next weekend if weather permits. I have both Bondo and JB Weld, which would be better to fill in the hole?
Shaving
if you just do bondo or body filler its just going to crack, you need some support, i did mine and i welded a piece of metal first, or you can jb weld a quarter then apply a coat of body filler over that, make sure to grind to metal for good adhesionLast edited by blackcb7; 01-15-2007, 03:15 AM.
If you bondo the hole shut, your gonna end up with a chunk of bondo the size of a quarter and a big empty hole in a few months. bondo isnt very strong by its self. save money, do it right.
also, Bondo shouldnt be applied over 1/8'' thick. or else expanding and contracting problems will crack it all up.-RIP Eric Hall. Miss you brother-
newskoolhippy (10:53:37 PM): i want to see a pic of you with a hard-on to prove thats your cock
newskoolhippy (10:53:56 PM): i need to see your face in the pic
newskoolhippy (10:54:07 PM): with todays paper in the picture to prove your taking it now
Originally posted by apuforyouI'm shaving my antenna next weekend if weather permits. I have both Bondo and JB Weld, which would be better to fill in the hole?1992 Accord LX - SOLD
i welded a Quarter in mine. its CuNi though so you need access to a TiG.
but if welding isnt an option use fiberglass mat under the hole then fill with tiger hair (Mar-Glas, or any fiber strand reinforced filler) then sand, one layer of bondo, sand, last layer of metal glaze, sand and feather then paint. viola!
CB7tuner.com Appearance Specialist - PM me with any bodywork questions
I dont have a welder and sorry if I sound like an idiot, but can i just JB weld some sort of quarter or a sheet of tin under the hole and bondo over it? Will the bondo still crack? And also if I did do the quarter or metal under the hole how well does the bondo stick to it? I do have the bondo mesh, but I guess its not good enough for this job?
hey sorry to jump in here but what kind of Metal Glaze is good to seal off the bondo becuase im doing rust repaires and the rust is coming through some spots of the bondo agian thanks, sorry for the sorta :P1990 Accord EX -Stock to no beyond
Originally posted by yeamans17you'd better soak the nuts in pb blaster, otherwise you'll snap them off
Vouch - | gloryaccordy | aznkid.com |
dont use bondo. If you must do it without welding, use a piece of fiberglass and resin and stick it under the hole from inside the car. (cut a long piece of fiberglass, tape the ends down, apply the resin to the middle part, let it dry, hair dryer will help speed that up, then once dry peel tape from ends and cut with scissors or sand down to get the loose mat off) . Then from the outside of the car use Fiber Reinforced filler, NOT just straight body filler. This will help avoid cracking. Now, fiber stranded filler doesnt sand smooth without pinholes, so you'll need to sand smooth, spread a layer of regular filler, sand that smooth then spread a layer of Metal Glaze. I personally use this all the time:
http://www.azautobodysupply.com/fievmegl30oz.html
enjoy!
