painting my stock valve cover?
    hey i did a search and couldnt find anything about painting the stock valve cover has anyone tried it? if so can u tell me how to do it to where the paint is smooth and doesnt come off? any help would be appreciated
    10th anniversary crew #1
    I'm not an expert in this, but I think it needs to be powder coated. -OR- you could polish it.
    It really is a labor of love making a neglected CB7 with "normal wear and tear" into something worth being proud of.
      there is a diy on powder coating in the diy section
        Here's what polished looks like..
          mines painted... Just sand the valve cover down and get some high heat engine paint. Comes out pretty nice looking... I'll let ya'll know how long it lasts but so far my buddy has done many like this and they all still look good.
          This pic does the valve cover no justice as it look a million times better in person.
          Oil leak?What oil leak? That's just sweat from all that horsepower!
          Applied knowledge is power!
          NITROUS FOR YOUR BODY
          BIRTHDAYS ARE JUST AROUND THE CORNER
          registration is free
            i like that painted one! looks good wut grit do u recomend using to sand it? cuz im going to use a sand blaster at school to take the factory paint off i just dont wanna sand it and paint it and there be sanding marks all through it. thnx
              Just sand off all the old paint and scuff up the surface with say a 1000 grit paper. You want the surface to be scuffed so the paint will stick... And then just apply paint until its all covered. if you see swirls, which you shouldn't, apply more paint to it until there gone... I think the a whole can of paint got used on my valve cover.
                ok thnx for the advice! do you think it would be ok to get the old paint off with a sand blaster?
                  I dont see why not. I did have mine hand sanded tho but I dont see any harm coming from using the blaster.
                    theres a great invention that can be found at schucks. its called Tal-Strip. buy a can of it and spray your valve cover. that will take paint off of anything. just spray water on it to get everything off. be VERY CAREFUL not to get it on your skin. your skin will bubble and peel off. it works like a charm, i used it.
                    Nitrous is like a hot chick with an STD. You know you wanna hit it, but your afraid of the consequences.
                    My Member Thread
                    ^ Updated pics 3/3/06
                      Here you go.
                      http://www.cb7tuner.com/vbb/showthre...valve+cover%2A
                      http://www.cb7tuner.com/vbb/showthre...ng+valve+cover
                      My H22A SWAP JOURNAL
                      Members Ride
                        well what i did was.. used paint stripper to get the oem paint off.. sanded it down real good.. taped off the lettering.. and then sprayed a couple layers or engine paint.. got it at auto zone.. turned out real nice
                        Frost White CB7 Crew #26
                          ok hers the process get paint stripper and color of high heat paint desired
                          shoot with paint stripper dont get it on your hands hurts like a mofo
                          spray off if all paint isnt removed spray again and concentrate on those areas
                          next clean througly
                          now scotch brite and clean again
                          now apply paint
                          watch paint dry
                          apply more paint
                          watch paint dry
                          let sit over night then clean it off or bake it then clean it off and install it with new valvecover gasket
                          the build and demise
                          buy stuff i want a new car
