OKay i dont have any pictures at the moment so hopefully i can explain this right. I recently got in a little fender bender and the part that goes across the front of the car that the latch is attached to, is bent in on one side. What i want to kno is, does that part come off seperatly, or am i gonna have to replace like a whole frame part?
Fixing front....help
the flat part above the headlight? that is attached to the middle bar that holds the latch on? The side pieces are welded on, so you would have to weld a new piece in. If its not too bad, you can just bend it back out. I am using the same side pieces, and I got in a "little" fender bender also. Check my sig for links to the pics. I just bent the side part as flat as I could get it, and bolted things back up to it.
