I searched for older threads but found no useful information. Anyways my dash clock would turn off and on when it was off i would hit it and it would come on. After awhile it no longer came on so I replaced it. New clock does not come on but at night you can see the numbers very faint the hour number is brighter than the minutes. Minutes are barely on. If I hold the set buttons or reset button it lights up brighter. It will not keep the set time as well. nothing was done to my wiring. only thing I installed since this issue was oem fog lights with oem harness. Fogs work perfect so I doubt its from those. If i wire the clock right to the battery it works perfect. What is going on any help would be nice thanks.
