Rescuing Ruby, Extensive Quarter Panel Rust Repair
    Used the jack from my van to push the back of the trunk compartment out. The latch is still a bit sticky, but the trunk lid now sits down where it is supposed to when closed.
    Used a load strap to pull the bumper bracket back out.
    I decided to stay with the 90-91 cover because I was able to straighten the bracket, the beams appear identical (I have several lying around), and the foam cushion survived the accident. Replacement remanufactured OEM rear cover is at Frank's being painted. Should have it back this week.
      Damn all that money spent for some careless driver rear ends you.
      1992 Honda Accord EX My Ride Thread H23A BLUE TOP Complete
        I would have felt like putting it in a glass bubble after all that restoration work!
          Back in one piece again. I hope that's it for a while.
            That's awesome dude . That is a really nice ride you have built your self .
            this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
            Car safety checks
            Fluid Capacities
              We need a :standing ovation: icon here ..
              edit: I found something ..
              Seriously man, so pure and perfect! Just awesome! Ruby should be AOM here .. soon!
                You sir have a beautiful stock car and should be acknowledged for your hard work and motivation.
                  Thank you. Future plans include rear disc swap. I already have an EX crossmember with sway bar (and EX sway bar up front), but the adjusting bolts for the lower control arms are frozen, luckily the alignment is still pretty good. I intend to rebuild (strip and paint or powder coat) the rear suspension from my wrecked 93 EX coupe, then swap it in and change the fuel tank as well; one of the strap bolt nuts stripped out of its bracket and you have to drop the crossmember to change the bracket.
                  It may be a while; I just got Silver (wife's 93 LX) back from the body shop for paint after front end repair. http://www.cb7tuner.com/vbb/showthread.php?t=197590 I have to install the rest of the front end.
                  Then I need to get the 92 coupe ready for sale. New windshield next week, still need a good trunk lid and two better tires.
                    Well, didn't get to the rear disc swap yet, but was smelling fuel from the rear - so it was time to change the tank. The old tank didn't look so good when I got it out; it was still running the original fuel pump.
                    Installed new tank strap brackets; requires dropping the crossmember. It wasn't as much trouble as I thought it would be.
                    New tank installed Saturday afternoon. I had replaced the main fuel line a few years ago, the other lines didn't look too bad. Brake line over the tank was rusty, knocked off the loose stuff and treated with "Extend" to neutralize the rust. Installation went well; no leaks or fuel smell when I filled it up. Recovered about 2 gallons of fuel from the old tank by powering the pump and squirting it into a can.
                      Best recovery vehicle on the board.
                        fleetw00d - love your work
                        You are real role model or any owner of classic and or ageing vehicle owner.
                        I must commend you on your patience and efforts.
                        What impresses me is your focus on repair, maintenance and not detracting from OEM quality fit and finish.
                        Almost ALL usually deviates and spend money on mods, speed, look at me show off items skipping out on the essentials.
                        You actually do what is needed first, thoroughly and properly.
                        I know not everyone has money but you are also one of the few that demonstrates understanding of boundaries of where DIY starts and stops (limitation of your own skill set and home equipment) and when to seek paid work rather than risking making a partly successful outcome or worse a mess of the job.
                        Well done!!
                        There is no hands clapping in the emoticons but if there was I would give you a few.
                        Rides:
                        Accord
                        92-JDM-2.0 Si- "4ws" - Cobalt Blue Pearl
                        96-AUDM-2.2 VTiS- Heather Mist
                        CR-X
                        88-JDM-Si- Black
                        CR-X Del Sol
                        92-JDM-SiR "Transtop" Motegi Edition - Silver
                        95-JDM-SiR "Transtop" Daytona Edition - Silver
                        92-JDM-SiR "Transtop" - Black
                        Prelude
                        91-JDM-Si-4ws "Si States" - Phoenix Red
                        91-AUDM-Si-4ws "Cita Lux Edition" - Bordeaux Red Pearl
                        91-AUDM-Si-4ws "Cita" - Cobalt Blue Pearl
                        91-AUDM-Si-4ws "Cita Lux Edition"- Gun Metal Grey
                          Wow I thought we did have that hands clapping icon in there. Can someone add that?
                          Is there a way to update the emoticon to add more? I'm sure there are more than this now on some forums (like the rolling around the floor icon).
                          Rides:
                          Accord
                          CR-X
                          88-JDM-Si- Black
                          CR-X Del Sol
                          Prelude
                            DOOOOOOOOOOOH!!! I'm an idiot! Got distracted pulling out of the driveway with another vehicle and brushed Ruby on the right side quarter. Really irritating that it was me that did it; my wife reminded me of my reaction when she wrecked hers (humble pie - see Saving Silver). Most of the damage to the other car was black rubbed off the bumper; most of it came off with a Mr. Clean Magic Eraser.
                            The Ruby saga continues. I'll send a photo to a Paintless Dent Repair guy I've used in the past and probably run it by the shop that did the paint work and see what they have to say (except "IDIOT").
                              I'm sorry too see that , but having seen what you have done, Tis but a flesh wound .
                              CB7TUNER.com
                              Educating each other one car at a time.
                                Oman, so true! And what's with Ruby always getting hurt? lol!
                                Gonna have to put her on the IR list for a bit till she's ready to get back in the game!
                                I agree with cb9love .. that'll just buff out ..
                                what an amazing thread!
