Hairline cracks in Carbon Fiber Hood
    I've recently noticed some hairline cracks in my CF hood...They're hardly noticeable, but is there some way to repair this? Or, possible cover it up. Thanks in advance.
    My Member's Ride Thread, Comments Welcome!!!
    all you really can do is paint over it.. i had the same problems from drilling for my hood pins and it's under the clear so you can't do much.
      what's done is done. many of have experienced this to some degree, some more than others.
      carbon fiber doesn't like to flex... seems that it will either crack, or perhaps cause delaminating of the gel coat/clear coat.
        mine has it right above the hood latch.
        JDMED
        buy my jdm part
        http://www.cb7tuner.com/vbb/showthread.php?p=544951#post544951
          Assuming the cracks are in the clearcoat itself, not the actual fiberglass/carbon hood...it can be sanded down and respray the clear coat, or if the cracks are small enough, you might get away with cut and buffing it out. But it is fixable, most body/paint shops should be able to fix it.
          Also you might wanna watch and see if it cracks more, the colder weather could affect it.
          Jay
          Hittin Switches - Draggin XhaustAlways Under Construction
            you cant feel mine. just see it. im not gonna worry about it
            JDMED
            buy my jdm part
              Same here, I guess the stress of the hood closing will ultimately cause hairline cracks. Mine's really not noticeable, I just don't want it to get worse.
              akkordlayinkit: Thanks for the advice man, I'll definitely call around, get some price quotes on something like this.
              Uncle_el: So true, it doesn't like to flex... I'm just glad it's not bad.
              Rebels: Painting over may work, but i'd rather just get a new cf hood. new cf hood=250, paint=500? Good idea though.
                You get CF hoods for 250? Damn dude, hook a brotha' up.
                '93 Bordeaux Red Pearl LX 5MT
                Prev CBs:
                -'93 BRP LX 4AT
                -'92 AGP LX 5MT
                -'93 AGP EX 4AT
                10yrs after my first cb, I'm still driving one!
                  I also have a hairline crack above the hood latch
                    I have some hairline cracks myself. As El said the movement of the hood can cause some delamination. I have noticed this condition over time in my hood :thumbsdow
                    Honda-Tech Username: Lostcb7
                    The cb7tuner.com OG.
                      250 for a cf hood, you must tell me where.
                        ditto^^^^^^
                        "Tucking tires and wires."
                        The Chronicles.
                          o0o
                          if i had one and it cracked id be making sure it was warrenty
                          Bump!
                            dude you cant warranty stuff like that. what if i caused the crack which i did. would you want to give me my money back if you sold it to me? there are too many posibilities(sp).
                            JDMED
                            buy my jdm part
                              Bump for info on $250 CF hood.
