does anyone know hot to remove the side molding, does it pop off or do u have to remove the inner door panel to get at it
side molding
i stuck a flat head screw driver behind it and pryed it up a little bit and then just pulled as hard as i could without damaging the body untill it popped off...but beware that u will break the plastic clips behind it and if u ever want to re install you can get them at your local honda dealership for about $10 a bag...
WHO CARES ABOUT THE STEREO, I WANNA HEAR MY EXHAUST!!!!!!!!!!
The moldings have little plastic clips on the back(they will break easy). The easiest way is to get the moldings off is to pry the first clip off with a screwdriver and then the other clips slide off, (slide the molding peice) either to the right or left, i cant remember which way. Or if that dont work, take the door panel off, then inner plastic linner, and squeeze the clip out.--jayHittin Switches - Draggin XhaustAlways Under Construction
Originally posted by akkordlayinkitThe moldings have little plastic clips on the back(they will break easy). The easiest way is to get the moldings off is to pry the first clip off with a screwdriver and then the other clips slide off, (slide the molding peice) either to the right or left, i cant remember which way. Or if that dont work, take the door panel off, then inner plastic linner, and squeeze the clip out.--jay
I would def take the door panels off. It is easy enough to do and you won't have to worry about breaking clips. Everyone hates broken clips.
http://www.tasauto.com - The Accord Experts
