Carbon Fiber Hood Closing Issue
    Ok, have had the cf hood for a little over 5 months now, didn't install hood pins because the latch seemed so well made and it hooked so nicely when closed, i figured I didn't need them...
    Long story short, my hood is having issues closing now, major ones, it sometimes closes, sometimes doesn't, if I pop it, it takes @ least 3-5 mins to close while playin around w/it. So, now I'm like wtf is goin on with this???
    Anyone else have this problem, keep in mind, it was fine for 5 months, no problems @ all. Secondly, I'm debating getting either mugen hood pins or momo. Good choices im assuming.
    Thanks fo the help.
    My Member's Ride Thread, Comments Welcome!!!
    Try pulling the wire by the lock assembly, i used to have that problem because the wire wasn't returning to locking position on its own.
      I had problems closing my hood, you got to take off the latch and mess around with putting washers in to make the latch line up with the hood better maybe, or try installing the hood either more upwards or downwards when you screw in those 4 bolts.
        Ok i know how to fix it when the hood doesn't close but without a pic it's gon be hard. Once i get home i'll try to write it down as detailed as possible. It takes like 10 sec to fix it with a flat screwdriver and some but kinda hard to explain.
        U silly rabbit don't u know tricks are made for kidz, You without me is like corn flakes without the milk! This my world, you just a squirrel trying to get a nut!!
          That would be awesome, hugely appreciated, because i've tried everything...
          and im goin to try all your ideas guys, asap. keep u posted.
            Why doesnt your hood close anymore? did it warp?
              On the latch on the car push down the part of the latch that has a spring connected to it.. It should fix that .
                could you be more specific? Thanks.
                  tighten the screws and slam your hood down!
                    It's CF (fiberglass shell underneath) not the brightest idea because you'll crack your hood pulling a stunt like that.
                    Honda-Tech Username: Lostcb7
                    The cb7tuner.com OG.
