Quarter Panel Replacement
    Where can i find reasonably priced replacement quarter panels?
    ebay, tas auto
      www.tasauto.com
        Originally posted by HondaFan81 View Post
        I put "quarter panel" in the search bar and all it pulled up was corner tail lights?
          http://tasauto.com/Product/detail.aspx?s=405800
          http://tasauto.com/Product/detail.aspx?s=405802
          http://www.cb7tuner.com/vbb/showthread.php?t=113942
            I was reading thru that thread you posted, so they still do not make replacement panels for coupes?
              So unfortunity they only make replacement panels for sedans.
                Bondo lots and lots of Bondo.... or JB weld take your pick lol
                -Will
                  No sir.
                  I do not advise you to use Bondo...
                  it will only come back out and leave you with the same problem you had before.
                  -Jordan
                  I ♥/Miss My Coupe
                    yep, sadly. i believe they have the same curve to them around the wheel well though. instead of using the whole piece, you should be able to cut the patch panel to fit just the spot you need to replace.
                      Thats what i read in this thread, just cut off the piece that would go behind the rear door (sedan) and use the rest of it to fix what rust i can.
                      I like uslspct's idea, Make a list of people with coupes that have rust around the wheel arch and when the list gets long enough have a manufacturer like "TASauto.com" produce them
