i was wondering if anyone could leave me some info. on how to safely and quickly remove the pin-stripe on both sides of the accord.
removing the pin-stripe
Lightly peel the end of it off with a razor WITHOUT going into the paint, then pull slowly pushing right before the spot you're going to pull up
Then wash & wax the car because there might be a faded line from the sun beating up the clearcoatAdam - Retired OG member from '03
there is a tool that u can buy that u can put on a drill and its really sticky and pulls off the pin stripe safelyLast edited by slammed4th gen; 10-07-2004, 03:41 PM.
i'm from mass too right near boston actually. i have seen heat guns used before to remove pin striping, but be very careful because if you use to much heat you will fuck up your paint, if you have a good hand you could razor blade most of it but that takes a steady hand so you can avoid scratching the piss out of the paint. try rebels approach first.
