removing the pin-stripe
    i was wondering if anyone could leave me some info. on how to safely and quickly remove the pin-stripe on both sides of the accord.
    Click Here for My Member's Page | Free money for searching the web. Needs PayPal account
    Lightly peel the end of it off with a razor WITHOUT going into the paint, then pull slowly pushing right before the spot you're going to pull up
    Then wash & wax the car because there might be a faded line from the sun beating up the clearcoat
      alright, thanks i'll give it a try once i bring my car home next weekend
        there is a tool that u can buy that u can put on a drill and its really sticky and pulls off the pin stripe safely
          Why where are you now? School? if so where do you go
            im at UMass Amherst right now...
              i'm from mass too right near boston actually. i have seen heat guns used before to remove pin striping, but be very careful because if you use to much heat you will fuck up your paint, if you have a good hand you could razor blade most of it but that takes a steady hand so you can avoid scratching the piss out of the paint. try rebels approach first.
                You can always use a plastic razoeblade.
                  I used a heat gun on it and it worked awesome. Came right off with no damage to the paint on the body like a razor can do.
                    your welcome.
                      I just did mine last weekend used a heat gun and a plastic razor blade worked fine
