Retrofit Audi A4 Projectors + D2C HIDs into 9293 housing, on a 91 EX
did you watch the new vids of the meet from Jerry?
I've seen 1 vid, I saw a car I recognized!! The silver coupe with dark pinstripes! It looks so much like a guy I used to work with from Hastings.. you happen to know his name?
A lot of nice cars there, hopefully a few more turn out for the next meet!
-mak
HAHA..yes I remember he said something about Hastings..
His name is Jim(black cool guy) ..I believe he is also a member here but don't post that much..
oh yeah, more should show up this time..
Hey, get some pics of the light in the day time..
Sounds like the same guy, but I thought his name was Chris or something.. ah well, maybe he'll be there for the next meet
Originally posted by CB7_ACCORD
one more thing;
CLEAN YOU PM BOX...I try to pm you but won't go through...
**Blk Housed Slut Crew Member #1** **Don't b scared be prepared for the worst** Da Drizzle's Sedan- Dr. Diy's Blk Housed Thread '90 2Tone Coupe-Car Heaven_'89 Lude-Junk Yard Mostly Usdm, some Jdm,Edm,&Puerto Rican RICE
I intend to bake the headlights and remove those yellow stripes, as well as the yellow backing on the high beams, and the blue backing behind the projectors.. then I'm going to re-apply a THINNER layer of yellow on the high beam backings, it's too thick as it is and the high beams look like egg yokes on the road!
I'm for sure going to remove the top and bottom yellow stripes, they're starting to bug me only 1 day later
I received my harness today, the wiring is a bit on the small side, but it should suffice for now (hopefully).
The only issue I'm having is that the headlights arrived with a broken nub, the round one that has that piece of plastic that wraps around it and screws down with 2 screws to the headlight mounting bracket.. on the underside of the headlight.
So the lights are almost unable to be adjusted perfectly, so I have to make an L bracket of some sort so it'll adjust correctly. It should work out, though.
