Balance Shaft Eliminate kit and H22/F20B Billet Timing Belt Tensioner
    TIMING BELT BILLET TENSIONER FOR YOUR H/F-SERIES ENGINE
    To build a reliable performance vehicle, you must start by eliminating known weak links. F/H series engine's utilizing hydraulic timing belt tensioner are notorious to fail at high rpm, causing timing belt to slip and in many cases resulting in catastrophic engine damage!
    Eliminate this weak link with a CNC billet mechanical timing belt tensioner; designed to be a direct and easy replacement for your factory hydraulic unit.
    Only $99.95!
    Direct Link: Bisimoto Store: TIMING BELT TENSIONER
    BALANCE SHAFT ELIMINATOR for your H/F-series.
    Inexpensive, simple upgrade good for over an 8 hp gain as well eliminate over 10 pounds of rotating weight, reduce internal friction, increase your oil pressure, and make for much faster and simpler timing belt changes!
    Full kit includes:
    -Required tap for your engine
    -Threaded plug
    -Billet steel plugs to maintain and increase oil pressure
    -Billet aluminum plugs for oil pump
    -Billet aluminum blockoff plate for rear balance shaft gearcase
    -Billet steel spacer to eliminate balance shaft drive pulley
    -Step-by-step instructions for easy installation
    Only $125!
    Direct Link: Bisimoto Store: BALANCE SHAFT ELIMINATION KIT
    CALL IN AT 888-922-6686 AND MENTION YOUR A CB7TUNER MEMBER AND RECEIVE A FREE GIFT WITH YOUR ORDER!
    Not to be a jerk but just curious about why one would go to a third party to pay the same price as the KaizenSpeed store.
    I wish you had it for a better price.
    Anythoughts on Bisi specific kits instead of reselling?
      Valid question. Bisimoto has a great relationship with KS and can stand behind these products knowing they will help the H/F community. Pricing is already such a low cost, we would not want to be a competitor to our manufacturer.
      What sets Bisimoto.com web store apart is that you can purchase these items and as well Bisimoto performance parts/services all at one time. If you have any other questions or wish to place an order over the phone, give me a call at 888-922-6686.
