The patented Bisimoto spec ATI Super DamperŪ is the only harmonic damper designed exclusively for high performance F22a, F22b, F18a, F20a SOHC-series engines. The proven elastomer design is actually two dampers in one: an inner and outer damper in two shells that bolt to the crank hub.
All units are SFI manufacturer certified and exceed SFI spec. 18-1. The patented Bisimoto/ATI Super DamperŪ also gives you guaranteed performance. Your car will run as fast or faster than with your present damper.
Dyno tests have proven the Super DamperŪ will allow the engine to produce as much as 45 HP over a Fluidampr at 7,500 RPMs and commonly 12 to 30 HP over OEM and other aftermarket brands in high boost appkcations. Timing accuracy is vastly imporved, and hence huge power gains are realized.
This is a must have for high rpm road race, auto-x, drag race and street/strip 240whp+ boosted and high rpm all motor setups.
Available in both street (grooves for ac, power steering and alternator)
and full race version (Grooves only for alternator)
$444.99 Street Damper
$474.99 Full race
$474.99 Full race
