Hey everyone,
I was inventorying some stuff and came across some sets of Bisimoto Spec Arias Pistons and Bisimoto Rods that we had done for a previous group. Most of them flaked but you guys can reap the benefits!
These bad boys are set for 9 to 1 compression and perfect for Turbo and N/A applications. We have 5 sets of these so get them while you can, $769 shipped!!!
After we sell out of these thats it! Shoot me an email if you are interested!
And a little info on both the pistons and rods
Bisimoto Spec shelf pistons, by Arias. ARIAS PISTONS has been the leader in compact piston technology since our beginnings. While piston suppliers at that time focused mostly on larger-bore domestic V-8’s, ARIAS had the foresight to cater to the smaller-bore, higher-revving, hotter-running imports & domestic compacts. Today, ARIAS maintains an unmatched advantage in the import and domestic compact market. Over three decades of research and development have led to the ARIAS Sport Compact shelf line. • Hi-tensile forged, not cast, billet material (4032 or 2618). • CNC machined working surfaces. • Optimized crowns for efficient combustion. • Diamond-turned ellipsoidal skirt profile. • Turbo/Nitrous pistons feature durable, heavy-duty design • All motor/Nitrous pistons feature lightweight, high strength construction.
Bisimoto Spec. Steel rods are manufactured from the very best aircraft quality 4340 steel. Using Autocad 14 technology, the Bisimoto Spec. rods are lightweight without sacrifice of strength. The Bisimoto Spec. steel rods feature 3/8" diameter ARP8740 bolts and have been tested to over 800 HP on a proper tune. Ideal for street, strip, road race, auto-x, time attack and full power competitions...n/a or boosted.
The small end bores feature bronze pin bushings for floating pin applications, with 3 (yes, three) oiling holes: perfect for shelf and custom forged pistons, providing amazing lubrication qualities in the most extreme performance applications.
