Misfire
    Misfire
    my car been misfiring for a while now the engine is bucking all the time i just got a full tune up fuel service only thing i need to do is replace the fuel filter and the car makes like a blowing sound idk but wat u think is causing it to misfire
    When you say a "Full" tune up, what do you mean?
    What was replaced?
    My 5.7 LS1 Holden Ute
      i got new spark plugs wire disc cap rotor filter oil change
        First thing is make sure your plug wires are where they are supposed to be...
          If the "blowing sound" you're hearing sounds like it could be air blowing back up into the intake, you might want to do a compression test after you verify that the plug wires are in the right places, and the timing is set to spec.
            i got the misfiring part fixed my intake manifold was clogged
              With what?
              Im honestly curious, not trying to be a dick.
              -Mark-
              CB7
              CD5
                what do u mean with what
                  I believe he wants to know what it was that clogged your intake manifold.
                    yup, thats what I was wondering.
                    -Mark-
                    CB7
                    CD5
                      carbon build up
                        I was hoping it was something interesting. Alas, it was not. Just Carbon Build-up. it must have been REALLY bad to have caused misfiring though.
                        -Mark-
                        CB7
                        CD5
