Oil Cooler question
    Oil Cooler question
    We all know that the f22a6 comes stock with an oil cooler (and if you didnt then now you do ^_^ ).
    My question is:will this oil cooler only swappable to other F blocks or can any car using the exact same filter adapt this cooler? (Both 00 civic ex <D16Y8> and 90-91 prelude Si <B21A1> use the same filter number that our cb7 uses
    Is there more to the oil cooler than that little attachment behind the oil filter??
    *(i wont associate other years, models, or blocks under assumption. ive only listed what i know to not mislead and ive never owned an a4 so idk if they have oil coolers either.)
    [COLOR="Magenta"]
    Its just a plate between the filter and block I dont see why not. Just see if all Honda oil filters are the same if they are should fit maybe.
      All the filters are the same and IMO all the oil coolers are too.
      Gary A.K.A. Carter
      [sig killed by photobucket]
        thanks for the answer g-man ^_^ you da man haha. imao go jack a cooler from the j/y for my 3rd gen prelude SiR. then ill have to hit up honda for the o-rings
        edit. i went to preludepower.com and found out that all 3rd gen preludes came stock with the oil coolers like the f22a6. so i guess i dont have to get one and work on it T_T sux to hear cause i was looking forward to a fun project
        [COLOR="Magenta"]
          if i rember honda has used the same filter since about 1974. should work but mite take a lil modifing
            i didnt know that they all used the same b4 this thread
            and a comment to your sig those are sooooo not real haha but i bet they are fun to play with.
            [COLOR="Magenta"]
