Ok there's a likelihood that I may have access to an eclipse gs-t that a fellow coworker of mine had but got impounded. Something massive broke on the suspension and car isn't drivable...he left it at a gas station and isn't going to try and get it out of impound.
I'm not looking for insane power...I'm looking for a simple build that will give me some gains...just to get some exp. with turbo tuning. And I can't think of a better project then the dsm turbo setup. Also, I don't want to do anything to greatly reduce the life of my honda.
I know a turbo will reduce the longevity of the engine...so I'm not looking for a lot of power...maybe 200 area...why bother with such low numbers you ask? Well like I said...I might have the opportunity and I want to keep the accord running well...and I need more experience before I go for 300-400 range. Of course for now I'm just going to buy the parts. I won't install until I can rebuild the turbo and some other things anyway
I've done some searching and found that the bore and stroke should work out...but what I can't find is this...
How are the internals of the 4G63T built? Are they forged rods? How are the pistons built?
From the reply in this thread , I take it the rods don't go in easily or simply.
I doubt the junk yard that has this car (if it has it) would let me take JUST the turbo, manifold, and injectors...so I'm looking at the whole engine. If that's the case I'd like to use as much as I can, but ONLY if the internals are stronger than stock f22 and only if they go in without a lot of fabbing.
I know I'll need the turbo, manifold, and injectors for this swap...but I don't know about the internals of the 4G63T engine...and I can't find anything out about it either.
Next question...how will the stock honda internals hold up to 8-10 psi with this turbo?
